Custom window not showing in model
Hi there,
I have a question which I hope has a simple answer.
I've created a very simple custom sashless window made up of a frame and three panes of glass, slightly offset and overlapping (Aneeta style)
Everything went fine as always (it's not my first custom window), I can see the window fine in the preview of the library part, but can't see it in the model, neither in plan view nor in 3D.
Attached images that show the library part window and the 3D view. Empty hole in the wall.
What am I missing here?! Any hint?
Thank you in advance
Could it be the renovation status of the window?
I always blame the renovation filters!
Or if you look at the 3D preview of the object (in the script window) is it a long way away from the origin?
Hi Barry.
Good pick. I normally check the reno status too but just didn't come to mind this time around. Also the window was far from the origin and that's something I knew but forgot since I haven't made a custom GDL for quite a while.
All good now, thank you so much for your prompt help
All the very best.
Claudio
