Custom window with arched lintel
Hi!,
I need to make a custom window, similar to the one in old factories.
They usually had arched lintels.
The problem is that when I put my window in the wall (previously saved as gsm window) , the hole in the wall is rectangular and lintel is straight, not arched..
What should I do so that it looked properly..?
thanks
Erich
Add a slab in the shape of the hole you want to your window before saving it out as a .gsm. Give the slab the element ID of "wallhole" then you will get the hole you expect.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
great Erich, thanks!
