Customize Door & Window Dimension Marker
Is there a way to customize these markers, so that the actual Door & Window dimension text on the plan, can be grabbed and moved arbitrarily, in a similar fashion to standard dimensioning texts.
I am using Archicad 8.1
Thanks
Mark
3 REPLIES 3
Thanks
Mark
You can edit the scripts and add moveable hotspots for the text if you are handy with GDL.
Otherwise you are stuck with what you have.
Seiss Wagner
But if you could use the Special Edition Library for AC9 you could move the markers all over the place just by grabing the hot spots and using the pet pallet.
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
