Customizing Window & Door Markers
I am using the "Window - Door Marker 70" to label my windows in plan. I'd really like to replace the sill value option with the rough opening height distance from the floor. I looked at modifying the marker 70 object, but I had no way of evening knowing how GS identifies the rough opening height in their code...
I did a search @ Objects Online, but could not find anything there. Has anyone modified the window marker to display this value?
Thanks!
Don
0 REPLIES 0
