Cuting
I am having a little troble I am trying to make a cut but not all the way thru the object... I need to have 3" on each side
cu_hood_length = 4'
Rotz 90
Rotx 90
CUTPOLYA 10, 1, ( (-cu_hood_length/2) + 3") ,
4.5", 0, 15,
2'10", 0, 15,
2'10", -1", 15,
3', -1", 15,
3', 2'10.25", 15,
2'9", 2'5", 15,
2'2.5", 2'5", 15,
2'2.5", 4', 15,
1'3", 4', 15,
4.5", 3', 15
Del 2
addx (-cu_hood_length/2)
Rotz 90
Rotx 90
Prism_ 6, cu_hood_length,
0, 0, 15,
2'10", 0, 15,
2'10", -1", 15,
3', -1", 15,
3', 5'4.5", 15,
0, 5'4.5", 15
Cutend
Del 3
Do you mean a void completely inside the body?
I think CUTPOLYA won't do it, it makes a half-infinite tube; it has only one end, the other keeps going. (Infinite both ways when d=0)
Solid Geometry Commands are the way to go. Page 109. Briefly, you need a GROUP of the target element, a GROUP of the subtracting body, then SUBGROUP(target, subtractor*).
*Maybe the other way around.
HTH,
James Murray
Thats makes life easy ....
Thanks
