Display malfunction of Graphisoft ID dashboard
Learn more
Use Outlines With GDL
Hi
i'm making GDL wood shutter for "savoyard" architecture style (that's in alpes)
the problem is that eveybody make different cuting in their shutter, somebodies draw heart , other trees, animal, circle, etc...
so i want to make the possibility for the user to draw is own cutting outline that he can save with the GDL object. To make this i thought to use the archicad outline, cause it's easy to draw with this.
How i want to make this:
1-The user draw easily his outline, with the outlie drawer of archicad and save it
2-The GDL object read in the saved aat. file and the user can choose is outline on a list in the Object Interface.
3- After with extruding and subgrouping the GDL create the holl with the drawed forme
so my questions are:
-I supposed that Outlines are saved in aat. files but i'm not sure. is it ?
-can i open/save aat. files from gdl script?
- i saw that we can save outline in Text file but their is no coordinates....
-Is their any solution to use archicad outline with GDL Object ?
thanks for your help..
David Maudlin
Jevrod:
aat files store project file attributes (layers, materials, etc., see the Attribute Manager), they do not store project elements, so this will not work. You might take a look at how ArchiCAD handles Custom Components (for example, a custom cabinet door) for ideas on approaching this problem.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Yeah i don't thought about that
i tried and it's ok
thanks
