DET_Lumber 19
Jeff Kogut
Seems to have stopped working by the finish fill going outside the boundary. I was able toggle the finish to blocking or continuous and it would fix itself yesterday, but it's back. It seems like this is since the recent library update.
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
David Maudlin
Jeff:
I cannot reproduce this bug. Does it occur for all object settings, or a specific set? Could you post a screen shot of the settings?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Jeff Kogut
We've been watching this in our office the last few days and it does not happen with newly inserted instances.
Our last big audit of details was when AC18 came out and we changed a bunch of the linework plates/beams we had to the DET_Lumber object. Our template has since been migrated to AC19.
For the error to happen it needs to have been migrated forward and originally inserted with Wood Style as Finish (as opposed to Blocking or Continuous).
They used to display correctly. In fact, they show correctly for an instant until updated.
I did update Java this morning, per another thread, and had hoped it would fix the issue - but, alas, it didn't. I'll have to send our intern through our detail library once again to fix all the instances.
