DO FAVORITES MADE IN AC 9 WORK IN AC 10 ?
Hi everyone
I have spent a lot of time setting favorite doors and windows in AC 9.
Do they work in AC 10 ?
I cant find out how ?
5 Replies 5
Andy Thomson
Mentor
Are you loading the same (AC9) library in your version 10 file?
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
David Collins
ION wrote:
Hi everyone
I think you have to export them from 9 and import them into 10.
In 9:
-Open the favorites pallette
-click on the very minimal arrow at the top right
-chose Save Favorites to create a *.prf file
In 10:
-same thing, only Load Favorites and look for the *.prf file you just created.
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
I guess it is not possible.
Thomas Holm
ION wrote:
Hi everyone
They may. However, I recommend you to start anew every time you start using a new Archicad version. There are several new features, also in the object libraries, that you will not be able to utilize if you just transfer your old favorites.
I tried the following:
1. In an AC10 file, I loaded favorites created in AC 9, the way David Collins proposed
2. I loaded AC 9 library, into the active libs of an AC10 file
3. I copied a wall with favorite windows and doors from an AC9 file and transferred their properties into AC 10 windows and doors
4. Now I have to rename favorites and create a new *.prf file
Does it sound ok to you ?
Is there an easier way?
Thanks a lot for your time .
