Door hotspots/zone/schedule relationships still a mystery
I posted to this discussion (http://archicad-talk.graphisoft.com/viewtopic.php?t=11381&start=0&postdays=0&postorder=desc&highligh...) but got no reply.
Does anyone have a solution to the fact that my door hotspots do not all show up (even with the parameters setting turned on and the Marker Setting "Show Editable Hotspots" checked) and I therefor have no control over which zone my doors relate to and can't get my schedule to read the way it should?
I've got several hundred doors on this project and need some help to get the info in the right format.
Thanks in advance.
3 Replies 3
Djordje
Thanks in advance.
Which library?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I originally started with the 9 library on this project, then moved to the 10 library that came with the release of 10, and now am using the latest 10 library.
Brad Elliott
I'm having a problem where my doors are associating with the zone on the story below and ignoring the zone on the story they are on. I have deleted the zones and recreated them to no avail. Has anyone else had this problem? Any suggestions for fixing it?
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
