‎2016-07-03 12:57 AM
IF GLOB_VIEW_TYPE = 2 THEN !do only in 2D
IF firstRun THEN !parameter that allow to run code only once
ch = OPEN ("DateTime", "", "%Y/%m/%d, %H:%M%P")
n = INPUT (ch, "", "", date)
CLOSE (ch)
parameters firstRun = 0 !prevents running code again
parameters date = date
ENDIF
ENDIF ‎2016-07-04 03:10 AM
IF firstRun = 0 THEN !parameter that allow to run code only once
CLOSE (ch)
parameters firstRun = 1 !prevents running code again
ENDIF
ENDIF
Because the default value for 'firstRun' if not set will already be zero.‎2016-07-04 08:50 PM
