‎2011-11-12
05:06 AM
‎2023-05-24
10:15 AM
Rubia Torres
‎2011-11-12 08:07 AM
‎2011-11-12 10:42 AM
‎2011-11-12 02:13 PM
Kevan wrote:The macro is in the AC11 Migration Library (ArchiCAD Library USA/Object Library 11/MACROS 11/D-W Macros 11/D-W Accessories 11/Door Accessories 11). On a quick read, it appears to be for part of the door frame, so if you can isolate the door, check the frame parameters for a zero value as Erich said. You could try setting the preview of the door to one of the 3D views so the error appears in the dialog box as you change parameters.
The project does not have an AC10 library. It has an AC11 Migration Library and an AC12 Library. So I don't understand how I could have a have an AC10 library part.
