Natanealll
Deleting an Image File From the Embedded Library Cause Crash
Hello
Everytime I try to delete an image file (in this case it's juts a regular jpg. image) and then click 'Reload and Apply', my Archicad just crashed. How do i fix this?
Oh, and also I'm still learning Archicad so I still don't know some terms here and there. So please elaborate the answer more, thankyou!
Bug ID : AC26-2024-03-11-15-47-29-2718
1 Solution
Natanealll
I just reinstall the whole whole app really, i guess something gets corrupted before.
Go to post
4 Replies 4
This is not technical support - so your Bug ID would mean nothing to us (your fellow users).  Assuming your version (which?) of Archicad has all updates applied, and your operating system (which?) has all updates applied - and the problem continues, contact the technical support for your specific country.  This is certainly not something that should happen.
Natanealll
Nevermind I got it fixed already. Thanks.
So, was there anything in particular you did to solve the problem?
It is handy to know in case this problem crops up for someone else.
Natanealll
