Yvonne
Different glass surfaces in windows
Is it possible to have difference glass surfaces in windows?
For example I want to make the lower transom glass a colourback glass whilst the rest of the window clear.
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
4 Replies 4
Only if it is scripted into the window - which for the default Graphisoft windows I doubt it would be.
But I don't use them so can't say for sure.
So if you can't find a parameter to control separate glass materials, it is probably not there.
I know it is a pain to do but you could try adding a morph in front of the glass for 3D views or if it is just in elevation you need it you can add a fill.
Lingwisyer
Guru
Could you do a custom sash with a different glass material?
Ling.
Yvonne
Thanks Barry and Ling
You're right there's no parameter for it in the default AC window. I don't want to complicate things so I found the easiest work around is to just split the window into 2
Infinite Openings does custom glass on each pane: https://www.youtube.com/watch?v=aNuNpAwHqfY&t=90s
You can download the tool here: https://cadswift.com.au/products/Infinite-Openings.html
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
