Dimension Marker
Steve Jepson
I need to have a prefix option as well as the suffix option in this marker.
Can someone add the prefix script to this for me and send it back?
Are there any Markers that do have a script for prefix that could be just copied and pasted into the script for this Marker ?
By null at 2010-01-21
David Larrew
Attached is your Part with your requested Parameter.
Please note that I overwrote your older part with the same name. You should make a copy of your old object and/or rename this one if you want to keep the original in tact.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Steve Jepson
thank you very much.
