MuriloNoleto
Dinamyc height
Hi everyone,
Is it possible in GDL adjust parameters in order to create a beam wich its height changes according to its lenght?
Thanks in advance.
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 29 | Win 11 |
I think you should be able to do this using the Parameter Script of the GDL Object. There you should create a formula or conditional statements for how the height should change based on the length change and then assign the result with the PARAMETER command to the Height parameter.
I have not tried this but I think it should work.
MuriloNoleto
Thanks for the advices Lazló.
I got a solution for this case - I did a combination beetween Parameter and 3D Script statements. Soon I will bring results.
Murilo Noleto
