Lingwisyer
Guru
Display Result in Settings
Hi all,
Can you have a results value within and objects Custom Settings? A parameter that has a value based off the user input into other parameters .
Or do I need to write up an Interface Script in order to provide feedback?
Ling.
3 Replies 3
Erwin Edel
Change parameter X and that changes Y? This works fine and will change right away.
You do need to make a script along the line of Y = X or more elaborate.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Maybe I am not understanding your problem, but an IF...THEN statement in the master or parameter script should do it.
Check the user input with the IF and THEN change your result parameter based on the outcome.
If you want to you can show the variables in the interface script, but the evaluating and setting of the variable will be done in the master or parameter script.
i.e.
IF user_variable = "Apples" THEN
result_variable =  "Apple Pie"
ENDIF
IF user_variable = "Blueberries" THEN
result_variable =  "Blueberry Pie"
ENDIF
PARAMETERS result_variable =  result_variable
Barry
Lingwisyer
Guru
*facepalm*
Was just missing the "PARAMETERS" command...
Thanks,
Ling
