Learn more
Dissappearing objects in sections
Does anyone know why some objects seem to dissappear in section view? I'm using structural beams which appear OK in 3D and 3D marquee but when I cut a section through the beam - it dissappears. Any ideas?
29 Replies 29
Aussie John
I've added a PLA file with two versions of the same object placed on the plan but rotated 180 degrees relative to each other.
View the section and one is visible in section the other isnt. Rotate the "invisible one" 180º and now it can be seen.
The object is a prism_ . The masking is set to "15" so all should be visible.
I have minimised the script for convenience.
The PLA file is a new and reset
Please let me know if anyone can see both objects
Cheers John
[/size]
Djordje
Ian wrote:
It is similar to the problem with stairs where they will sometimes dissappear in marquee 3d view whilst being visible in full 3d view. The dissappearing beam objects will also dissappear in 3d if cut by a marquee but will be visible if the marquee does not cut them.
Did you try re-saving them as 9 objects? That should help; this is a known bug (part of objects not showing when in marquee).
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Aussie John
Anyone? This is a serious problem for me as it occurs with a number of objects. I can do a workaround by rotating and mirroring but if another section looks backwards then the pronblem moves to the second section.
Is opening and saving all that is needed to do this as i have done that? There was a command in the special menu to do this but I dont seem to be able to get that menu to show.
Cheers John
[/size]
John,
I could not see both upon opening the section, only the one on the left. Then I rebuilt the section, and both were visible. I cut a new section, and both were visible. After that I tried rotating, mirroring, etc, no disappearance. I tried with direct reading, and saving a library. Same result. I haven't observed the behavior you described in my own work. Probably not much help. Good luck,
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Aussie John
James wrote:
John,
Thanks James that does help me as it says something wrong with my system rather than the object.
Cheers John
[/size]
John,
I have been able to replicate the same behavoir as you. In other words the beam is sometimes visible and sometimes not depending on the orientation of both the beam and the section. We are both using the Austarlian verson of ArchiCad 9 - do you think this has anything to do with it?
Aussie John
Maybe although seems unlikely.
Cheers John
[/size]
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Dear Aussie,
I found the reason and, from my point of view, it should be better to send a report to GS because this sounds just like a bug or… a not requested feature!
From what I see it isn’t related to the beam object but with all the ArchiCAD library parts!
Look at the attached image.
I inserted two chair and I got the same behaviour you have with your beam.
The explanation/solution is quite simple.
In both cases (beam and chair) the library part insertion point is “out” of the section/elevation range.
If you move your section/elevation limit in order to include the insertion point (BTW I’m talking about the default insertion point or probably the object origin) the chair (or the beam) will be displayed.
A simple “temporary” workaround is to avoid to rotate the object but to mirror it (look at the attached image).
Please, tell us if you will submit this report to Graphisoft otherwise I will submit it by myself…
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
The second image, still about the beams...
Fabrizio Diodati
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
and just the same behaviour with two other library parts...
Fabrizio Diodati
