Does Archicad 16 have track lighting objects
Need some 12' tracks for track lighting, is there any track or track lights in Archicad 16? All I find are silly curved spotlights, not what I need.
4 Replies 4
Have you checked the BIM Components library?
Found something in a Germanic language and guessed how to make it the length needed and to arrange the lights in a balanced way, but couldn't figure out how to show more than three lights
The Spotlight Kit 16 in the standard library has a straight track option (in addition to the curved), and you can select 2-6 lights. I think you need to play around with the options a little more.
Also, if you don't like the canopy, say, you can always "Convert to Morph" and edit this as you wish.
Richard
AC26 (since AC6.0), Win10
Thank you so much for your suggestion, it was so helpful, and your thoughts were so helpful too! However I found one to download...see below
