Door Casing not showing in Section
I'm am trying to activate my door casings to show in section but they don't seem to want to show up. They are showing in 3D & in the settings dialog, but I can only get the width of the frame to show in section and not the casing itself.
I thought it may have to do with my frame thickness being set to 0 but I changed this to 20 and it doesn't seem to have helped. I also can't see any Model View Options that would control the casing. Any help would be greatly appreciated.
2 Replies 2
Section screenshot. I have also played with the scale sensitivity settings without luck.
If you start a new project with New & Reset and place a Door with default setting, does the casing then appear in Section?
If yes, then there must be some setting for that Door in this file.
I tried this on a newly created file and the casing is there for me in Section too.
