2006-08-16
10:47 AM
2023-05-24
11:03 AM
Rubia Torres
2006-08-16 03:46 PM
2006-08-17 02:17 AM
Matthew wrote:Thanks Matthew,
Why are you using the label tool instead of a door/window marker?
Matthew wrote:We already had a marker which did this but it was actually part of the doors 2D script. It was done this way at the time as noone had any idea how the markers worked nor the time to work it out. Maintaining this in all the door objects we use isn't very efficient so im now trying to fix it. We'll see how it goes ...
Programming the marker to align automatically with the door leaf is very tricky (I still haven't had time to sort it myself). The simplest way to do it is with two parameters for XY and one for angle with some dynamic hotspots to allow the user to fit it up properly.
