Door Selection Settings - (Door with sidelight on side 2 20)
Hi, I have a door with fixed timber louvres as the sidelight section (front entrance door) and I would like to be able to include a vertical double sash window overlapping on the inside of the louvres.
Do I need to increase the sidelight rebate depth to allow space for the inclusion of a vertical double sash window with the window tool, or can I achieve this all with the door selection settings?
What is the best way to do this? I've looked through the door selection settings and tried to change the sidelight section into a window and add a sunshade as the louvres, however I was not able to combine them correctly.
Any suggestions would be greatly appreciated.
0 Replies 0
