ā2007-05-18
04:26 PM
ā2023-05-26
11:35 AM
Rubia Torres
ā2007-05-18 04:32 PM
ā2007-05-18 04:40 PM
ā2007-05-18 10:30 PM
ā2007-05-18 10:35 PM
Jeffe' wrote:Reverse steps 1 and 2, or you may end up with a Label in
1. Give your window a uniqe ID and check the "Label Elements" box
2. Go to the Elevation where the window is, be sure the "Label Elements box is still checked for that window. You should see a Label arrow close to the window.
3. Select that label, go to its settings. Change the box from text to "Label Window Marker 10"
4. Change whatever setting you need to in order to make it look right.
ā2007-05-21 02:31 PM
ā2007-05-22 12:51 AM
Dan wrote:IMHO that is the strength of labels.
Also, be aware that labels can be set on any layer and may not show up when you check the "Label Eelments" box if the label tool is currently set to a hidden layer. If this happens find the layer and turn it on so you can see the label.
Dan K
ā2007-08-06 11:09 PM
Aussie wrote:This is the procedure I use to apply Labels.
Before selecting any door/window, double click on the label tool, select both doors and windows and set your parameters, layer and choice of label there. Next time you select "label ID" your label will pop up without lots of setup.
ā2007-09-28 04:40 PM
ā2007-09-28 05:29 PM
