3 weeks ago
Hi there,
How would i change the marker head from a triangle to a circle in archicad 29?
There seems to be an option to change the marker head in older archicad versions but not here.
Solved! Go to Solution.
3 weeks ago
I don't use change markers.
But it looks like you can't be using the 'built-in' marker.
Change it to the 'basic' one instead.
3 weeks ago
If you mean section and elevation markers, it should all be the same as before.
In the section/elevation settings.
3 weeks ago
- last edited
3 weeks ago
by
If you do not have the options Barry is showing, check which marker you are actually using.
Ling.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
3 weeks ago
Sorry, no I mean for change marker.
It only shows it like this...
3 weeks ago
3 weeks ago
Thank you.
