‎2006-06-29
05:29 AM
‎2023-05-26
11:39 AM
Rubia Torres
‎2006-06-29 06:09 AM
‎2006-06-29 01:18 PM
‎2006-06-30 04:53 AM
‎2006-06-30 05:27 AM
Andri wrote:it would suggest that your 'floor plan cut plane' was at the wrong height . . . traditionally and typically a plan 'view' is a cut through the building at about 1000>1200mm (depending on which graphic convention you were taught) above floor level. this, of course, was fudged by drafties wanting to show graphically those elements that wouldn't be cut by this plane . . .
I found my solution, i change the wall setting in the wall window to "symbolic cut", so thank you all for helping me put.
‎2006-06-30 12:44 PM
~/archiben wrote:In order to have projected windows, you have to have an automatic wall. Automatic walls are way more trouble than they're worth IMO, when we're speaking of simple vertical walls. The multi-story aspect is not worked out re doors and windows. (Openings showing on remote stories, etc.)
my view is that you should follow this kind of principle virtually with AC10. so, rather than simply setting everything to 'symbolic' and calling it done, set your 'floor plan cut plane' (which should be found in the 'view' menu) to a level that graphically represents your intended plan view and then switch those elements which don't appear correctly to 'symbolic'. doors and windows can each individually be set to 'symbolic' as well.
i think it's going to take a little bit of ironing out - this is a new approach to plan view creation by graphisoft - but in the long run we should see the benefits of being able to generate multiple plan views at different levels through the same storey: think mezzanine floors, clearestory windows, high level stairwellsYes, but they are much closer to the beginning than the end. As for now, my walls are as 9-style as possible: One story, symbolic, symbolic openings. Save the special bits for special applications, profiled or slanted walls. The walls can't even reflect being trimmed by a roof, forget about SEOs. Sorry, this whole 'Automatic' paradigm isn't ready for prime time. (Although the roofs are pretty awesome.)
‎2006-06-30 04:45 PM
James wrote:I'm with James on this one. Even if a major new feature were to work perfectly, the implications for workflow are usually too complex to adopt wholesale. But the reality is that major features are not (and cannot be) fully developed when they are first introduced and have to evolve in the wild (through actual use by all of us).
‎2006-06-30 05:05 PM
ML wrote:And remember when the detail tool came out you couldn't place a detail inside a detail window, and now we have the floor plan cut plane!
evolved
‎2006-06-30 05:18 PM
James wrote:And remember when they first introduced the label tool and how it was hardly usable, and now... oh, well... never mind
