Door casing setting - where?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-03-07
02:13 PM
2023-05-26
11:20 AM
Rubia Torres
2012-03-07
02:13 PM
Thanks
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-07 06:31 PM
2012-03-07
06:31 PM
What library part are we looking at in your screenshot? When I set "Frame Style" to "Style 2" (stop shown) in a D1 Entrance 15, for example, the stop is right against the door panel, as it should be.
Thx,
Thx,
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-07 06:38 PM
2012-03-07
06:38 PM
Oh. Got it. This is really bizarre: if I make the door panel thicker, the 'stop' moves away properly. If I then reset the panel to a thin panel, the 'stop' does NOT move back! It stays at the deeper distance: bug I think?!
Nothing in the UI panel controls this ... but it is set by the parameter "Door Stop Projection" in the "Door Frame" parameter group. Just reset this to match the door panel leaf thickness and all should be well. I think?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-07 06:44 PM
2012-03-07
06:44 PM
Karl,
That was D1 Internal 15, but the same thing happens when I use Entrance. I've got it set to "Solid wall" as the wall will just be studs with no finish
What is your door panel thickness set to?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-07 06:46 PM
2012-03-07
06:46 PM
Sorry, just saw your response after I posted.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-07 06:48 PM
2012-03-07
06:48 PM
Karl wrote:Yes, that works! Thanks.
