Door dimension marker problem
We have a problem with door markers. We're working on an archicad 20 teamwork project. When someone drag a door, the door dimension marker move with the door as usual. But after someone else has received the revision, altough the door is in it's accurate place, the dimensions marker stays in it's former position. Is this a bug or something about the display options?
Ceren
3 REPLIES 3
Is this a Door Dimension that you set in the Door Settings Dialog?
Or is it an associative Label that you place for the Door?
If it is the first, then it looks like a bug to me.
It's not an associative label so it should be a bug then.
Thank you
I will report this to GRAPHISOFT.
