Learn more
Door direction
I am sure that this is a common issue for beginners but I could not find it with the forum search engine.
How do I change the direction to where a door opens?
I don't know if my question is clear so here's a little screen cast to explain myself.
http://www.screenr.com/1HBs
The other software is Autocad Architecture but I want to learn Archicad because it seems a better BIM solution.
Best regards,
Carlos.
1 Reply 1
Hi Carlos,
Try using the Mirror command (Edit > Move > Mirror).
Hope that helps,
Adrian Tudoreanu
