Door problem
Hello everyone!
Can you please tell me why I cannot change the material of the leaf of all my doors? I select glass and I see wood. To all the doors. And I cannot find the material of the case.
Vivi
Erwin Edel
Check the Model View Options (MVO) of your 3D window, they might be set up to simplify the 3D detail of the door, losing the glass panel.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thank you so much!
I couldn't understand why was this happening since in other projects this wasn't an issue.
Thanks!
