‎2004-03-17
09:01 PM
‎2023-05-24
11:06 AM
Rubia Torres
‎2004-03-17 10:55 PM
‎2004-03-17 11:02 PM
Aussie wrote:Thanks, John... I've read the code. I'm looking for the DOCUMENTATION to give to a typical end-user?
the door leafs are macros and as such are ordinary objects. (look in dw macros of main Archicad lib)
‎2004-03-18 02:24 AM
Karl wrote:Could this be what you're looking for?
...I'm looking for the DOCUMENTATION to give to a typical end-user?
I know I've seen a PDF file from Graphisoft or elsewhere with the information on the new door types and constructing custom panels ... just can't find it.
‎2004-03-18 08:56 AM
‎2004-03-18 07:29 PM
Petros wrote:Thank you, Petros! I skipped that link numerous times since I had no interest in doing Storefront Windows and Doors
Karl,
at the US graphisoft site there is a PDF in the download section about new storefront -door-windows![]()
On page 8 there is a small description about the use of custom panel:
‎2004-03-18 07:34 PM
Sergio wrote:Thanks, Sergio ... but that was about building an entire custom door ... and this is a special feature apparently only in the US library where you can take most existing AC library doors and keep the frame and all other parameters, and substitute your own custom panel (leaf). Petros found the reference below...although they do not show an example in that PDF.
I think the original post on this came from you ...
‎2004-03-18 07:56 PM
‎2004-03-18 11:04 PM
David wrote:That's it!! Thanks, David! Good sleuthing!
This might be it:
http://www.graphisoft.com/community/envisions/03.11.jtburk.html
‎2004-03-24 08:26 PM
Karl wrote:I created my own DIY DOOR a few years ago (objects Online). The proceedure that worked for me is as follows. I guess that it is the same for these doors:
but they are indeed skimpy instructions. To avoid distortion, one would assume that the door panel (leaf) has to be built to the exact size desired ... and the steps do not indicate if project zero refers to the center of the core of the door (for making door trim appear more to the inside or outside), etc. So, it looks like I will have to play with this.
Does anybody use this custom panel feature?
