Find the perfect object, manage libraries, create custom objects
Doors-Tick box for "zone into which it opens" does nothing?
I've noticed this slightly on other projects but on a recent (larger) project I am working on wether I have the tick box checked for "Door belongs to zone into which it opens" makes absolutely no difference to the schedules.
To make the door pick up the correct zone I have to "flip" it, which then has the door opening the wrong way, and still no difference using the check box.
Has anyone had this issue? Is there a work around? Otherwise I'm manually writing over 150 doors because they can't pick up the correct room and instead only pick up the corridors.
2 REPLIES 2
Which Schedule field do you have a problem with?
This checkbox has an effect on the Zone Name and Zone Number listing parameters in the General group of parameters. It has no effect on the To Zone and From Zone listing parameters in the Window/Door group of listing parameters.
I was using From Zone and To Zone, which grammatically speaking solves the issue! Probably should have looked into that and my own logic.
Perfect, fixed, thank you!
