ā2008-10-22
08:46 AM
ā2023-05-26
11:29 AM
Rubia Torres
ā2008-10-22 09:33 AM
ā2008-10-22 09:44 AM
ā2008-10-22 10:35 AM
Susanne wrote:Thanks for the reply, i'll sort out my signature when i get a moment
Hi there stranger,
could you please add a signature and by that tell us what ArchiCAD version you are working in, and what OP system as well (not that this particular issue has anything to do with the OP system, but for future inputs)?
Anyway, a quick guess is:
- that you somehow has turned the doors and windows OFF in the Model View settings dialogue?
- have not used symbolic 2D symbol in plan view and by mistake hasplaced yet another wall?
-or even turned the 2D symbol OFF by misstake?
... screen dumps of AC 11 version
ā2008-10-22 02:27 PM
Sambosbag wrote:"Symbolic" should work, but the wall containing the door needs to be set to Symbolic Cut also. If you do not set the walls to Symbolic Cut, then you will need to understand the Floor Plan Cut Plane, which is covered in the help files.
It was the 2D symbol, i had it set to "symbol", but it wasn't showing, so i think i tried every one other than "overhead"....which of course was the one that made it show up![]()
ā2008-10-23 03:42 AM
ā2008-10-23 10:03 AM
Bier wrote:Im having huge problems with my story heights actually.
And if all that does not work, maker sure your story height is correct.
I've had story height (for what ever reason) end up as one foot.
3d will look right, but 2d won't.
Bier
ā2008-10-23 01:40 PM
ā2008-10-23 01:47 PM
