Doors
When working on a building, how can I get the floor coverings to show under the door? They always show the concrete or wood under them but I can't get the carpet to go under it. I have tried Thresholds but doesn't completely do the job.
4 REPLIES 4
Dontknow
Is this what you're looking for: Video?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
I get this every time I do it. The only way I have found to do it is is I lower the foundation 1/4" and then run the carpet. But that leaves a gap between the wall and the floor
Dontknow
Do you change the top of the floor into carpet or do you draw in the carpet separately?
ArchiCAD 25.
Draw it per room. Like the last Office I did the hallways were tile and the rooms were carpet
