Drawing Scale Object
Hello all.
We are working on A1 worksheets which most often we are printing them on A3 (50%). I am trying to create an object that shows the scale in both paper sizes as and it would look like:
A1 / 1:100
A3 / 1:200
It is simple to compose the first line with the usage of autotext (<DRAWINGSCALE>) but the actuall text in GDL is "<DRAWINGSCALE>" so i can't use the "1:100" value to SPLIT the text and then convert the "100" to number to multiply it and compose the other line.
Any ideas?
Thank you.
2 Replies 2
It is not possible to read the actual content
of an autotext.
Tyvärr.
Peter Baksa
Hi, you need GLOB_SCALE.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
