WINDOW TRIM BACKWARDS IN PLAN
Not sure about this one. The window trim on the exterior is showing up pointing the wrong way in plan. In elevation and 3d it looks correct, but not in plan. I have deleted the windows, rebooted, reinserted, and they still keep coming up this way. On the last project they were fine. Not sure what is going on here. Any ideas. I have attached a screenshot so you can see what I am referring to.
Thanks for any tips.
Paul
7 Replies 7
Are you having the same problem in all windows?
Did you tried copy paste a window from other project where the windows are good? if so what happened? if they came good, did you use eye-drop and inject parameters on the bad window?
I did a copy/paste and eyedrop from the other project and the same thing happens....very strange. and it happens with every window in this project. Fortunately it is a very small house, so not a ton of windows.
Ok, that's wear, I have never had this problem before.
One last thing comes to my mind, what about copying a window (with the wall) (copy paste) to a project where windows are working right?
I did that too, and when I pasted the wall, the window trim went wonky. I just don't know whats going on.
Wow, that's really strange, as a solution, I'll be doing the trims manually in the mean time, but report this to Graphisoft it might be a bug, or lets wait for the experts here to see if they have a solution.
I have solved the problem. Not the cause tho. I opened a new instance of archicad and copy/pasted the project into the new one, and windows are fine. Go figure.....
Thanks for the feed back tho...
OK, Thanks God, is solved whatever it was.
