Duplicated Library Objects
Suddenly my Library Objects are getting loaded twice.
Can't figure out why, how to stop it, or how to remove the duplicates.
The library report indicates over 3500 duplicate entries. See pic.
This is not project specific. It affects both existing jobs and a New from Template incarnation. (Both ArchiCAD 10 and my own GGA 10.tpl are affected)
Any suggestions as to what has gone wrong and how to correct it, please?
10 REPLIES 10
Looks like you have 2 libraries with identical objects loaded -- what does your Library Manager dialog look like?
Lib Man opened up on C: as Local.
Sure looks like a straight duplicate but can't tell where it is coming from or why.
Your library manager is only showing a single instance of the AC10 library. Is there any chance it has another copy inside itself?
Ahh -- this must be it.
I have now looked through my file list and there doesn't appear to be a duplicate library within the existing file structure.
Is it possible that my GGA Template file has accumulated it's own copy of the library file somehow, which then gets loaded a second time? If so, how would I track it down and kill it?
Sorry about the triplication... it kept coming up with a Debug Error saying that it had not transmitted. (It lied)
1. You can delete the multiple posts.
2. If you read the duplicated parts message all the way to the end of the line, it will tell you where the part is residing.
Richard
AC26 (since AC6.0), Win10
