We value your input!
Dynamic variables
i am trying to make hotspots that are editable, and use a unique ID tag. i am wanting this tag to be dynamic so the unique ID is HOTSPOT<int i>
for example:
WHILE i<10 DO
Text2 0,i <prints `HOTSPOT`i>
i=i+1
endwhile
which would produce the following text:
HOTSPOT10
HOTSPOT9
HOTSPOT2
HOTSPOT1
i was thinking i could join the string "HOTSPOT" with INT i. i have done something like this in other languages however am not sure if it can be done with GDL. I used a TEXT2 example. however i am looking for a way to take the string that TEXT2 would have displayed and use it an the unique ID for a hotspot.
thank you.
I think all you need is a counter of sorts in your loop. It's discussed here.
Thank you very much! that helps alot.
