ETFE Cushion Rotation
Hi, I'm using AC13 on a MAC. I have created a 3 plane ETFE .gsm object using three mesh surfaces. From this pc I don't have a pic to show, but you can understand this to be a 3d 'cushion' in floor plan view.
Now, I need to have this cushion at a slight angle (x or y). I was succesfull using objective to do this however, it is a very heavy action in terms of processing time. I also found this rotation plug-in by peter devlin, but have no idea how to use this.
Anyone that can help me with this, either by explaining how peter's plug-in works OR showing maybe an example of the code to be implemented in GDL?
I appreciate it.
Thanks and kind regards,
Peter de Ruijter
9 REPLIES 9
thanks Peter, i will test it!
Peter -
Peter wrote:
Now, I need to have this cushion at a slight angle (x or y). I was succesfull using objective to do this however, it is a very heavy action in terms of processing time. Anyone that can help me with this, either by explaining how peter's plug-in works OR showing maybe an example of the code to be implemented in GDL?
OBJECTiVE makes your object rotatable by adding rotation parameters and scripting, i.e. using native GDL. The speed is therefore entirely dependent on GDL - I would be surprised if the object processed any faster by manually editing the parameters and scripts. Let me know if this is not the case.
Ralph Wessel BArch
Central Innovation
Hi, my impression is that it took much longer to generate the rotated object. I wash literally processing for 10 + minutes, it was a bit scary actually.
This is very strange. Processing time depends primarily on the number of polygons and their angle of rotation should make little or no difference. Is this mesh particularly complex? On my machine 10 min would be a long time to generate a complete building model. I don't think even one of my large hospital models takes that long unless I turn on all the MEP stuff.
Hi, to me it's not too complex. It is three mesh planes, of which the middle point of the first is elevated (z) 500 mm, and the middle point of the third is elevated (z) -500 mm. The middle place is level.
Attached a .tiff of the object in floorplan view.
Am interested to have your opinion!
Peter -
I'm intrigued - can you email the object to me? Either use the email address on Encina's contact page or PM me (putting email addresses in these posts would just invite a flood of spam).
Ralph Wessel BArch
Central Innovation
Hi Ralph, in the end I actually used encina, and that worked like a charm. The problem was with OBJECTIVE rotation. That took a long time. Would you still like to receive the object.
Peter -
Yes please. I want to ensure any slowness isn't due to an error in OBJECTiVE.
Ralph Wessel BArch
Central Innovation
