Edit a Sub Type
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-06-17 11:07 PM
‎2015-06-17
11:07 PM
life of me figure out how to access the "sub types". Can anyone refresh my memory?
Thanks
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-18 03:33 AM
‎2015-06-18
03:33 AM
It is just like any other object - you can open it by name so long as you can remember what is was called (and where).
Otherwise you can use the 'Select object by subtype' command.
It may not be in you menus if it has not been included in the Work Environment but you should find it in the GDL toolbar.
You will still need to know the name although it may be easier to spot if you don't and it will also show you all the objects using that sub-type.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-18 05:27 PM
‎2015-06-18
05:27 PM
Thanks Barry
It is not in my work environment which is why I couldn't find it.
Mystery solved.
Mystery solved.
