Element ID...
Llian
Is there a way to attached element ID to an object so that I don't have to enter it each time I place it on the drawing? It just makes find and replace easier.
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
DGSketcher
Legend
Have you tried Favourites or possibly using ID Manager?
About ID Manager - https://helpcenter.graphisoft.com/user-guide/77120/
If your default tool settings has an ID, then every element you place will have an ID.
As suggested use favourites if you want different IDs.
If the ID has a number in it and the ... Work Environment > More Options > assign new element ID to new elements ... is on, then the number will automatically increase for every element you place.
You will still need to do some manual adjustments or use the ID Manager because if you copy & paste or drag a copy, the ID will stay the same.
