fuzzytnth3
Elevator 14 downgrade?
Anyone know why the Elevator object in AC14 does not have the same user interface as the Elevator 02 13 object does?
Main things I miss are the user stretchable hotspots which allow you to edit the Elevator Shaft Width and Depth and the wall width. Daftest thing is that the custom parameters tab is not available in the AC14 version but the AC13 has a nice UI
Seems weird to go backwards
Below are screen shots of the AC13 object
And here are the AC14 versions
With the AC14 version you can only edit the shaft wall thickness within the Object settings whereas the AC13 object lets you edit it in the 2d plan window
Here the AC14 object does let you stretch the shaft size but it doesn't have the nice "tabs" to edit just the width or the depth as you can in the AC13 version
Why?
Using AC25 5005 UKI FULL
0 Replies 0
