Error Mess: Cannot DEL transformation ??
Dave Jochum
5 minutes before a client is due in my office I find what I think is a duplicate slab in the section window. I delete it, and without saving (so I could just undo if necessary), view the model in 3D to make sure I didn't just trash something I wanted. (I was unsure, because in plan, selecting all did not show a duped slab.) As the 3D window script is running I get about 20 error messages like the one attached, but with different line numbers referenced. I went to undo, but it was greyed out. Just my luck I guess that an autosave had just taken place. It obviously refers to casement windows, none of which I touched in deleting the slab. Can a GDL guru out there tell me what this means and how to fix it?
TIA
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
30 REPLIES 30
Dave,
Why don't you post the part so we can take a look at it? I am curious how this could happen, it doesn't make any sense.
Dave Jochum
This is driving me nuts. The only time I can get the error message today is when I re-draw the 3D window with the entire model. If I select any portion of the model, either with the arrow or either marquee tool, I don't get the message. I also don't get it opening selected windows in their parameters settings box, which I was last week. So now I can't figure out which windows are causing the problems. I've included one below that I think was giving eror messages last week.
Well...I tried attaching a MOD file which apparently is not allowed. What's the best way to do this?
Dave Jochum
Send me the module at:
matthew@lohdensteele.com
I don't know if I can figure it out, but I can at least take a look at it
Djordje
Dave, did you delete the library cache?
If you want to post anything that is not in the allowed file format, zip it first.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dave,
No luck with the module. The error did not recur and I cannot see any problems within the library parts (the report you posted showed the error as occurring in a couple of the macros called by the main window object).
It may be best to just replace the windows.
Aussie John
I am sure you have a parameter setting which is causing the error. Place a new window ( with the default settings) in a new wall and see if that works ok. Gradually change the parameters to reflect the errant ones. Hopefully you will find what is causing the error.
Cheers John
[/size]
John,
How can you be sure it is a parameter setting? I can't imagine why anyone would write a library part that would allow a user parameter to cause this particular error. Deleting transformations is an entirely internal function. Besides I have looked at the code of the macros where the error is reported to occur and the DEL statements are not parameter driven. (I say "reported to occur" because I was unable to recreate the error.)
Dave also indicated that the error only occurs when the entire model is generated. Apparently when the offending casement is modeled in isolation the error goes away. This was also my experience, but I am not using Dave's libraries, so I have too many variables to narrow it down.
Aussie John
of course I cant be 100% sure but with looping etc it is possible to write a script that works 99.5% of the time. But an odd combination of parameters might throw it out.
Are all the Graphisoft library parts completely bugfree? I doubt it.
I didnt see that he said it works in isolation.
Dave, have you tried picking up the paramerters of the object (opt click) and inserting a new window?
Cheers John
[/size]
Of course it's possible, just VERY unlikely. Transformations are rarely (if ever) driven by user parameters.
Aussie John
Let me give you an example
If a window had a parameter to select anumber of panels and you inserted 0 then unless the programer used error trapping you would probably get a transformation error ie trying to delete a a transformation that never happens because the parameter is 0
Sure I'm clutching at straws but Dave has had this problem for a while to no avail
Cheers John
[/size]
