Error in double door properties
Hi there seems to be an error regarding the double door library part in ArchiCAD 22. When a clear glass panel is shown in the dialogue box, the doors appear with a timber / opaque panel in the model (both elevations and 3D representations). Has anyone else come across this and know how to solve it? Thanks in advance!
1 REPLY 1
Lingwisyer
Guru
Check the MVO options within the door itself.
Door Settings and Opening... => Detail Level => 3D Detail Level
Ling.
