Error when writing/reading an array
TomWaltz
This is kind of a strange problem.
I am reading a Text file into an Array:
	DO
		n = INPUT (ch1, i, 1, keynote)
		IF n > 0 AND VARTYPE (keynote) = 2 THEN
			sarray = keynote
			j = j + 1
		ENDIF
		i = i + 1
	WHILE n > 0
...which I am later in the script trying to retrieve:
	i = 1
FOR i = 1 to arrayLength
		split_char = ",," ! Two commas, field delimeter
		keynote = sarray
		test_text = keynote
		txlen = STRLEN (keynote)
		tx_split = STRSTR (keynote, split_char)
		IF tx_split > 0 THEN	! If there is a Split Character found
			keynote_num = STRSUB(keynote, 1, tx_split-1)
			keynote_text = STRSUB(keynote, tx_split+2, txlen)
		ELSE
			keynote_num = keynote
			keynote_text = " "
		ENDIF
		GOSUB 110
		GOSUB 120
	NEXT i
Subroutines 110 and 120 actualy try to process the text to place it on the drawing.
This script does not have any errors when I run "Check Script", but I get an error when I try to save the object. The debugger tells me I have a "String type expression required" error on the line that reads "keynote = sarray"
What is really odd is that if I replace the with a number, like [4], the whole thing works.
Is there something obvious I am missing here?
Tom Waltz
10 REPLIES 10
Rob
ok then, I was just checking...
back to your previous question.
when you are reading the values to the array it does not matter wether the value is a string or a number
so:
sarray=""
for rowNum=1 to 10
n=input(ch1,rowNum,1,sarray[1])
n=input(ch1,rowNum,2,sarray[2])
n=input(ch1,rowNum,3,sarray[3])
next rowNum
text file: blabla,1,0
sarray[1]=blabla
sarray[2]=1
sarray[3]=0
::rk
