Radim
Exception for Level 0
Hello everyone,
After I switched to ArchiCAD 23 I found that exception for Level 0 does not work in Sections.
In ArchiCAD 21 there was not such a problem with it - as you can see in picture.
So, is there any way to render the slice properly?
Thank you in advance and have a nice day.
11 Replies 11
Minh Nguyen
Radim wrote:
Hi Barry,
Thank you very much for your work.
The problem is:
In older versions of ArchiCAD I set the Layers Intersection Group to zero and though the override fills are the same, they will not blend and line will remain. ArchiCAD 23 have not exception for Level 0, for the Layers Intersection Group.
Thank you for the suggestions but i need a system solution. Maybe i return to ArchiCAD 22.
Screen zoom % is probably a hardware problem.
Thank you and have a nice day
Radim
Hi Radim,
Thank you for sharing the issue!
From your description, this looks like a defect with layer intersection group, one of which has already been fixed in the first update of ARCHICAD 23 (build 4006). If you're still in build 3003, could you update ARCHICAD 23 to the latest build?
Unfortunately, the update is available for INT and some other language versions at the moment. The package for CZE has not been rolled out yet. Once it passes QC, the update will arrive soon!
Let me know if this helps with the issue!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Radim
Hi Nguyen,
thank you for the info. I'll wait for the update.
thank you and have a nice day
Radim
