2018-05-02 12:03 PM
2018-05-11 09:50 AM
2018-05-11 02:26 PM
Piotr wrote:Excellent! Didn't even consider this. Thanks very much!
I have not tried it... but if a called string is a variable....it may be doable
some kind of:
xx=""
xx="somefile.gsm"
call xx ....
I am not sure if it works... just thinking loud...
in UI script - such way called bitmaps are not included in pla... so maybe the same will work for gsm's
(file_dependency command must be used for them to be included...)
Piotr
2018-05-11 02:42 PM
2018-05-14 02:55 AM
JGoode wrote:In the Work Environment > Imaging and Calculation you can turn off error messages.
Is there a way not have an error show up if the call isn't successful?
Thanks
2018-05-14 03:39 PM
2018-05-15 03:13 AM
2018-05-15 05:00 PM
Barry wrote:Excellent idea! I didn't even know such thing existed in ArchiCAD. I think it's as close to perfect as i'm going to get.
So you have an object that CALLs another object that has the link you mention?
I don't know how many licenses you have but can you use REQ ("Serial_number"0 and then compare that to a list of your actual licences numbers?
Then if there is a match, go to the link or even still CALL the link macro.
I haven't tried this but I think it should work.
Of course you can password protect your object so your license numbers are safe and can't be altered for anyone to gain access to the links.
