abdelaziz
Explode an object
Hello
I hope that with the integration of building materials in the GDL script, Archicad can explode an object created in ARCHICAD into native elements (wall, beam, slab, shell, roof .....) "in some cases Limit the use of modules linked "
I hope that with the integration of building materials in the GDL script, Archicad will be able to merge the materials of construction of the Objects with the native elements (wall, beam, slab, shell, roofing ...)
AMD Ryzen 5950x
AMD RX 9070xt
AC28
0 Replies 0
