Extra accuracy STR{2}
Hello!
I need to mathimatic rounding:
0.0245 -> 0.03
But in this code
value = 0.0245
string_result = STR("%.2", value)
i have
0.02
May be i need to use STR{2} with extra accuracy flags...
But in documentation of GDL no examples ((
Please, help me!)
2 Replies 2
Tsepov wrote:
Hello!
0.0245 -> 0.03
But in this code
value = 0.0245
i have
0.02
Please, help me!)
2.4xxx will mathematically round to 2.0
The rounding point is 0.5
If you add something to it then it will round, but no program i know will round a 0.4 to the next hole number...
With crazy clients who wanted custom rounding, we built rounding factors that we added to numbers to get the desired result, i.e. you could add 0.005 to your 0.0245 to give you a roundable number
therfore
a 0.02450001 that displays 0.025 at 3DPs and displays as 0.02 at 2DPs
becomes 0.02500001 that displays as 0.025 at 3DPs and displays as 0.03 at 2DPs
it depends on the level of accuracy that you work in...
runxel
I suppose you don't actually want to "round" something, but to make it always bigger. This is called ceiling.
There is indeed a function called "CEIL" in GDL, but the result will be of course Integer, not Float:
c = CEIL(-2.25 )   ! =-2
w = 25.276
w = CEIL(w)        ! w=26
So if you want it to remain Float you need to e.g.
con = 100
n = 0.0245
n * con    ! n=2.45
n = CEIL(n)     ! n=3
n = n / con     ! n=0.03
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
