In your 2D script there will be a TEXT2 command to add the text for the name.
i.e. TEXT2 0,0, identify
You will wnt to change this to TEXT2 0,0, STRSUB(identify,1,4)
I am assuming you are using the variable "identify" to hold the name of the composite.
But watch out because it looks like when your "gs_content_type" parameter is not `Composite` then you will have a blank "identify" parameter and no text will appear.
I can't say for sure without seeing all of the script.
