Polar Bear
Favorite - library
Hello Experts,
Maybe easy question:
I am not able to save certain library items onto favorite: such as some doors and some windows.
What i am doing wrong???
Thanks a lot!
Kind Regards
Martin
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
4 Replies 4
That door is taking part in some sort of connection (Solid Element Operation?) - you can see the grip icon in your image.
Maybe that is why it can't save as a favourite?
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Martin,
Thank you very much for the report!
I looked in our database, and there was a similar case with saving a door as a Favorite. We found out that the door used a marker that was not found in the loaded libraries, thus Archicad failed to save the door as favorite. I'm wondering if that's the case here?
If not, I would like to ask for the file for further checking. Please let me know if you need a secure place to upload the file also!
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Polar Bear
Thanks for the reply,
Yes a secure place would be good. The same happens with one of the window.
Thanks a lot.
Kind Regards
Martin
Archicad 25 - 5010
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Martin,
Thank you very much! I sent you a link in Private Message where you can upload the file directly to us for further investigation.
Please let me know when it is ready!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
