File for Marker
Where are Markers saved in AC?
5 REPLIES 5
TomWaltz
The are embedded in the Object Library. lcf file.
I usually find it's easiest to place the marker, select it, then click File > Objects > Open object.
The other alternative is to extract the LCF file, which creates the library folder structure as hundreds of files and folders
Tom Waltz
Thanks Tom
That is the why I miss nice markers from NCS-office in German version.
But in american version this marker is there.
As you mention, I open this one through selection the marker.
I couldnt find the file for marker.
There are better libraries for kitchen parts in German version.
You can take it if you want.
General/Markersymbol 10
Thanks
Rod Jurich
When you get 11 you will need to set up your WE with access to a menu called "Open Object by Subtype".
There you can access all markers to set your defaults.
See attached for additional info.
Rod Jurich
I have AC 10.
It is nice file structure for AC 11. Very nice.
